Wireless doorbell
Other more automatic and permanent solution would be to fit a flow sensor to your bathroom hot water pipe and wire it to a solenoid valve fitted to kitchen sink hot water pipe, with a small by pass flow, so that if someone does open the kitchen hot water tap they will only get a trickle flow of hot water and the rest will be diverted to bathroom upstairs when it is in use, when bath is not in use kitchen will get full flow.
I was thinking along similar lines - not quite as sophisticated as that (actually controlling flow to the kitchen tap) but, rather, simply a flow sensor in the bathroom hot feed which activated some sort of audible alarm/bell downstairs.
Kind Regards, John
Finally some decent advice!!
Unfortunately iv done my kitchen up fully tiled so no access to pipes going upstairs anymore :(
And sad to know all bells are going to be 433 MHz what a load of rubbish
The light thing not really that good Option as it would lock tacky and may get missed ie garden hose etc
Ps you're right it's cold and hot water from downstairs that can mess up shower flow not just hot
Only thing I wonder is does a digi/video sender that operates at 433 interfere more than a bell that operates at 433?
Ie is frequency more strong and therefore stronger interference??
Digi sender had 1x transmitter and x3 receivers - plus always turned on
Bell is just turned on now and then???
Finally some decent advice!! ... Unfortunately iv done my kitchen up fully tiled so no access to pipes going upstairs anymore :(
Are there no pipes at all between boiler/kitchen and bathroom that are accessible (e.g. under bath etc.)?
That's a bit different from the 'usual' problem with a combi-boiler, and could perhaps be addressed by improvements to the cold water plumbing system. However, in terms of the idea discussed above, a flow sensor on just the hot (or, indeed, just the cold) feed to the bathroom could be used to run a bell/sounder in the kitchen.
Only thing I wonder is does a digi/video sender that operates at 433 interfere more than a bell that operates at 433? ... Ie is frequency more strong and therefore stronger interference??
Exactly what sort of consequences of 'interference' are you experiencing. Many of us have countless 433 MHz devices in our homes without any obvious or major problems (just occasional slowness of responses). Particularly given that the wireless doorbell you propose would presumably be used only occasionally, are the 'consequences' not things you can live with?
Kind Regards, John
The video senders basically screwed up my last alarm siren in that it would no longer work or respond but I'm gonna try with this wireless bell and see as it's far easier than flow sensor!
Thanks mate
Thanks mate
You might also try, whether it will work or not I am not sure, but does tend to work with me, under the sink you have ball valve isolators to cold and hot water taps, to facilitate changing washers etc, without turning the whole water supply, these ball valve isolators could be adjusted with a screwdriver to such a position to give you a limited flow to kitchen hot water tap, enough to allow the boiler to fire i.e. 3 to 4 liters per min yet restrict full water when the tap is fully open, this could allow a person taking a shower to at least not get any hot water but some, so you don't get soaked in completely cold water, ater, I I found no matter how many times I told my wife not to open hot water when I am taking a shower, that bitch always does that, I think she hates me and is only sticking with me for my money!
When that used to be the case, before I adjusted the ball valves to restrict the hot water flow, I had to step right outside the shower to stop getting showered in icy cold water. Now at least the water does not get totally cold and stays warm enough to continue having shower.
Any ways, there is definitely something wrong with your alarm bell, if it gets triggered by something as simple as a door bell, what if your neighbour bought one like that, would that not keep setting your bell off, so you need to look into your alram system, and if necessary have it replaced.
That seems very odd. Do you mean that the siren would not work even if/when the video senders were not in use? If so, even if some external influence had some immediate effect on the siren, it should not have any lasting effect - so I think the primary problem must have been with your alarm siren, not any interference it was subjected to.
Kind Regards, John
Yes tbf it may me a rubbish siren but the video senders did cause interference to it and some sensors but since packing video senders away and getting a new siren fixed iv had new issues and just use magic eye instead
But Im gonna order a bell anyway hopefully it doesn't cause any issues as rather than muck about with Any plumbing it's the easier way
http://www.ebay.co.uk/itm/150M-Rang...910659?hash=item4640cd5ac3:g:faoAAOSwwPhWijTu
See bottom of description it says 315 / 433 MHz hmmmmm 315 only would be ideal!
And yes you're right the neighbour could have something 433 I don't know what common items runs on this but so far nothing has messed my alarm again lol
There are lots of illegal items sold on ebay. To you it's a doorbell, to the person trying to legally use that frequency it might be the thing that interferes with ... I don't know what that frequency is reserved for, so I can't say it isn't used in life-saving applications. On the other hand, it might unlock all the cars in your street, or change everyone's TV channel, or ???
315 MHz is the normal frequency for short-range devices in the USA, just as 433 MHz is here.
As far as I know, all wireless devices work on an approved and licence free common frequency such as 433Mhz, but the communication protocol or in lay mans term the transmitted coded information differs, such that one manufacture will have his own protocol so that his devices don't clash or register with other manufacturer's, receiving devices, however if manufacturers were using generic or commonly available coding and decoding integrated circuits in their applications then this is where codes could be duplicated, some therefore make a provision to allow an end user to make small changes to protocol so that transmitted code is different to a similar device using a different code, they normally provide a bank of switches to make small changes to the code or so called channel setting, so likewise your bell may come with a channel set switch, and may have two or more channels to choose from, the idea is if your neighbour also owns the same brand of door bell, then his may set off yours and visa versa, so one of you will have to change the channel switch so that two door bells won't trigger each others door bell, same way your alarm panel that communicates with your external alarm bell may be getting triggered by an identical code from that door bell transmitter so if your bell has a channel setting switch you may select a different channel setting and it may no longer set your main alarm bell off.
I am assuming that it is not just the strength of RF Carrier from your door bell that is causing interference to your alarm bell thus triggering it off, that is possible but highly unlikely, otherwise your alarm bell would have been going off more frequently from other stronger radio waves transmitted from lots of other devices such as mobiles and wireless modems and so on.
Some wireless devices can be swamped by receiving continuously strong RF signals such that they cannot communicate effectively between a control panel and a remote device as the coded information gets corrupted by stronger signals and it is like you are trying to whisper to your partner whilst your mother is using a hoover!
A fantastic simple explanation thanks so much
Ps bell is untested it was the video senders that was causing interference with alarm
The bell I haven't tried and tbh will not try the 433mhz cos I don't want it interfering or messing alarm up in any way and last time he charged me £50 to replace siren
It's just a massive shame I can't buy that 315mhz bell problem solved :(
