    Dismiss Notice
Wiring a new hob: can I use Wago connectors?
Discussion in 'Electrics UK' started by Mefster, 28 Jun 2020.
  1. Mefster
    Mefster
    18 Feb 2012
    14
    Thanks Received:
    Cheshire
    Country:
    I’m in the middle of replacing a cracked electric hob with an induction hob.
    I’ve removed the old hob- it appears to have the twin and earth supply cable hard wired into the hob. There is no junction box visible.
    The replacement hob comes with an attached cable. On removing the covering plate on the hob where the cable inserts it doesn’t appear that it is designed to have the supply cable directly wired into it. The terminals are not visible.
    I’m going to connect the fixed cable on the new hob to the supply cable, but was wondering if I’ll be ok to use Wago connectors for the job (covered with insulating tape)?
    The maximum power of the new hob is ‘6.400 W’ (I’m assuming that’s 6400W rather than 6.4W!) so at 230V I was calculating just under 28 Amps.
    I’ve got both Wago 221 and 222 connectors. Would they be suitable?
    If not, what would be best? I’m hoping I’ve got the bits I need, otherwise I need to refit the cracked old hob to cook dinner tonight!
  2. Sponsored Links
  3. bernardgreen
    bernardgreen
    3 Nov 2006
    23,190
    Thanks Received:
    2,217
    Bedfordshire
    Country:
    NO. it would require the connections to be enclosed in a suitable protective box which also must provide secure cable clamps for the cables.
    • Thanks Thanks x 1
  4. Mefster
    Mefster
    18 Feb 2012
    14
    Thanks Received:
    Cheshire
    Country:
    Thanks for the fast reply. Would something like a Wagobox junction box be ok? Using 221 connectors?
    If not, what kind of junction boy would be best suited?
  5. johnny2007
    johnny2007
    11 Jan 2012
    1,134
    Thanks Received:
    176
    London
    Country:
    • Thanks Thanks x 1
  6. bernardgreen
    bernardgreen
    3 Nov 2006
    23,190
    Thanks Received:
    2,217
    Bedfordshire
    Country:
    The 221 is rated at 32 amps.
    If the box is water proof and has cable clamps ( or strain relief ) to ensure the cables cannot pull on the connections inside the box then the box should be OK, The box should be fixed to the wall and not left dangling
    Better in the long term to fit an appliance outlet such as the one posted by johnny2007.
    • Thanks Thanks x 1
  7. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,241
    Thanks Received:
    1,937
    Oxfordshire
    Country:
    What size cable are you using? My guess is you'll have 6mm from your CU? Probably the same to the hob?
    Look at the spec for those connectors. Yes they are rated at 32A BUT 221 and 222 can only handle up to 4mm².
    • Thanks Thanks x 1
  8. Mefster
    Mefster
    18 Feb 2012
    14
    Thanks Received:
    Cheshire
    Country:
    If I was fitting new cabinetry I'd definitely go down this path, but at the moment I only have about 15cm gap between the top of the back of the carcass and the granite top through which I can see the rear wall. I don't see how I could het adequate access to fit a back box. I think my only way is to screw a junction box to the wall.
  9. Mefster
    Mefster
    18 Feb 2012
    14
    Thanks Received:
    Cheshire
    Country:
    I've just realised that as well when I had a look at the diameter of cable into the hob!
    Looks like the new hob is coming out again and the old one going back in until I can get some 6mm 30A rated connectors and a junction box!
    Does anyone know of a suitable product (ideally that I can pick up from screwfix or get delivered from amazon) so that I can complete the job?
    Thanks!
  10. Sponsored Links
  11. johnny2007
    johnny2007
    11 Jan 2012
    1,134
    Thanks Received:
    176
    London
    Country:
    Confusing.
    Any pictures?
    Sounds like you have just a cable coming out of the wall.
    Anyhow, if you pull your oven out (2 or 4 screws) you will have plenty of space, unless you have a non conventional set up.
  12. johnny2007
    johnny2007
    11 Jan 2012
    1,134
    Thanks Received:
    176
    London
    Country:
    Sorry, double post.
  13. Mefster
    Mefster
    18 Feb 2012
    14
    Thanks Received:
    Cheshire
    Country:
    Sorry, reassembled to cook dinner before I took any photos.
    The hob isn’t over the oven: it sits over some drawers. The cabinet beneath the hob which houses the drawers has an encased back so I can’t see the rear plaster wall, except for a gap about 10cm at the top (through which the twin and earth power supply cable is fed).
    Does that make sense?
  14. Mefster
    Mefster
    18 Feb 2012
    14
    Thanks Received:
    Cheshire
    Country:
    Here’s a photo: a bit of a mess I’m afraid! Hopefully this shows it a little more clearly...
  15. johnny2007
    johnny2007
    11 Jan 2012
    1,134
    Thanks Received:
    176
    London
    Country:
    Don't know if it complies, but you could fit a patress box at the back of the cabinet and then connect a cooker outlet.
    An electrician here could confirm if feasible.
    Surely would be neater and easier.
  16. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,241
    Thanks Received:
    1,937
    Oxfordshire
    Country:
    Yes, no problemo
    • Like Like x 1
  17. bernardgreen
    bernardgreen
    3 Nov 2006
    23,190
    Thanks Received:
    2,217
    Bedfordshire
    Country:
    You could remove a small area of the back board to get access to the wall to fit the cooker outlet on the wall.
Loading...
Share This Page
