Wiring modular switche
2 Jul 2013
Warwickshire
I've checked the wiki and there's nothing in there for wiring up modular sockets and switches.
I want to replace some ugly 2g FCUs with modular units housing a 13a outlet and a switch for the sockets supplying my integrated appliances.
The existing FCUs are in-circuit with a spur off to an unswitched socket for the appliance. Where I'm getting confused is that I want to put an outlet in the new module - that's simple; just terminate the 'in' and 'out' into the 13a outlet as you normally would, but how do I then get a live feed to my switch for the spur and what do I then do with the neutral which feeds my appliance outlet?
Thanks in advance!
Never seen a two-gang FCU.
Is it?
Are you getting confused with connecting to the ring and supplying the appliance.
There are connections for each on an FCU.
However, you do not need an FCU. There will be a fuse in the plug.
Just use a 20A double pole switch although neither is necessary unless you want to do it.
Do they make two gang FCU's?
Show us some photographs of what you have.
Is it?
However, you do not need an FCU. There will be a switch in the plug.
Sorry - looks like I worded that badly. The existing FCUs are 1G, I'm replacing with 2G modules so that I can have an extra outlet above worktop.
If I was only replacing the FCU with an outlet module, there wouldn't be any confusion because it's no different to wiring up a normal outlet. Doing this will put the outlet in the ring circuit in place of the FCU. However, I need to also fit a 16a switch module to switch my integrated appliance. Once I've wired up the new outlet for the module, I'm only left with my twin&earth which feeds my appliance socket. The new switch module only has 2 terminals (one way switch) live1 and com. I would normally terminate the live for the appliance socket into the com terminal. This leaves me requiring a live feed for the switch (do I just run a single live between the other outlet module and the switch) and also leaves me with a neutral going to the appliance socket and nowhere to terminate it.
What's the difference between one of those
and one of these:
and one of these:
That's simply a 2G switched socket. What I'm doing is a 2G modular frame with a single unswitched 13a outlet and a switch which switches an outlet in another location as required for all integrated appliances.
Not only is it not required, IMO an accessory with a switch and a socket outlet which is not controlled by the switch would be unnecessarily confusing for people.
Interesting! Kitchen fitter I know said it was a requirement now! Might reconsider in that case...
It's not 'required' (by any regulation); it is fashion and up to you if you want one.
While I agree it is not a regulation, I'm not sure it is just fashion either - after all it still appears as Guidance in both the Yellow On-Site-Guide and the Electricians Guide to the Building Regulations.
Although a cluster of 20A DP Grid switches (with name plates) do look better.
