I second fixed a kitchen last week that was only partially rewired, they had 6 FCU's along one wall!! Grid switches would definitely have been better, only needed two fuses. It looked ridiculous
I've not got the yellow OSG - what does it say?
A standard socket outlet with its own double-pole switch meets this.where an appliance is supplied from a socket outlet or a connection unit, this should be controlled by an accessible double-pole switch or switched fused connection unit.
More poor wording, I suspect! I imagine that they meant to write something like "...where an appliance is supplied from a normally inaccessible socket outlet or a connection unit, this should be ...".SO, if I read the GUIDANCEA standard socket outlet with its own double-pole switch meets this.where an appliance is supplied from a socket outlet or a connection unit, this should be controlled by an accessible double-pole switch or switched fused connection unit.
Does it reference an actual regulation?Notes to Table H7. Onsite Guide Yellow edition...
Not directly from the notes section. H7 itself references 553.1.7.Does it reference an actual regulation?Notes to Table H7. Onsite Guide Yellow edition...
Indeed it can, but you may nevertheless be underestimating the potential 'power' of guidelines. In many fields, a lot of operational details are dealt with in 'guidelines', rather than regulations or legislation. Although, in a literal sense, compliance with guidelines is not 'mandatory', official bodies/agencies often put a lot of weight on what the guidelines say when reaching decisions as to what actions, proposals or whatever are 'reasonable' or acceptable. Just as it's not mandatory to comply with BS7671, demonstrating that one has complied with Part P would be an uphill struggle for most people if they hadn't complied with BS7671 (which, as far as the law is concerned can, I suppose, be thought of as a ('non-mandatory') 'guideline').It doesn't matter what is meant. It is guidance so it may be reinterpreted any way seen fit.
Indeed. However, even if the scheme operators make it 'mandatory' for their members to follow that 'guide', the law obviously doesn't impose a corresponding insistence. I presume that the scheme operators could require you to also comply with the OSG if they wanted to (I think they require you to have an up-to-date copy).Alright, 7671 is the guide we (as per schemes) must follow.
I would certainly agree in terms of "third party guides", which represent the opinion of an individual as regards interpretation and implementation of the regulations. I would, however, say that it's a bit different when the guide is published by (and presumably written by) the same organisation that publishes the regulations. There's a similar issue in terms of the relationship between the 'Approved Documents' and the actual legislation they relate to - both published by 'government'.Writing these others which differ is therefore - what's the word? - futile and I am astounded at their power and the power of fashion.
Unfortunately they do, but do not know why.Indeed. However, even if the scheme operators make it 'mandatory' for their members to follow that 'guide', the law obviously doesn't impose a corresponding insistence. I presume that the scheme operators could require you to also comply with the OSG if they wanted to (I think they require you to have an up-to-date copy).Alright, 7671 is the guide we (as per schemes) must follow.
Which applies to mobile equipment.Not directly from the notes section. H7 itself references 553.1.7.
But there's a disclaimer in the OSG which says it might be a pile of negligent incompetent poo and in the Preface it says that following it does not ensure compliance with BS 7671, which people should always consult.I would, however, say that it's a bit different when the guide is published by (and presumably written by) the same organisation that publishes the regulations.
