Hi yesss it was HETAS and we have the paperwork. The gas has been completely disconnected we can pull the vibe valve out and patch the wall just haven’t yet!Bring it forwardAlso , what's that on the left of the surround near the floor ? looks like an old gas fire valve and pipe . A job for gas safe to remove . Was the install HETAS and registered with paperwork for you?
It's possibly not as bad as you think?Would a smaller wood burner have been better?
I think the dog is taking all the heat
Best thermal stores.. ever!I think the dog is taking all the heat
Thank you. I will contact the installer and ask them to bring the stove out of the surround as much as they think possible to see if that helps.I guess it depends what your priorities are. If it was me I would move it forwards. If it was the installers idea to shove it into the back of the fireplace like that I would definitely get a different installer who knows what there doing! I take it the mantle is marble as I cannot see a wooden one meeting HETAS. BTW my priority would not be a plasma thing either but each to there own![]()
Indeed BUT I think you will have to find somewhere else for the plasma as a lot of heat goes upwards even with stovetop fans!Thank you. I will contact the installer and ask them to bring the stove out of the surround as much as they think possible to see if that helps.
That would probably be a good place to start anyway wouldn’t it instead of selling the stove and getting a new smaller one.
Yeah we might need to if more heat comes out and up. Currently the stone mantle is protecting the TV the underneath gets warm but the top of it is really cool and hardly warm at all!Indeed BUT I think you will have to find somewhere else for the plasma as a lot of heat goes upwards even with stovetop fans!
hahaha no surprise there as the stove is BURIED in the fireplace doing very little, wait till you get it out and installed properly!! Anyway suck it and see ......Yeah we might need to if more heat comes out and up. Currently the stone mantle is protecting the TV the underneath gets warm but the top of it is really cool and hardly warm at all!
Thanks! That’s very true. Would getting a smaller be better in that case? The hearth can’t be increased it would be a case or completely removing the fireplace surround and replacing with new hearth and mantle I think xxJb, is the chimney void directly above the stove blocked off with a register plate? It should be, and the flue pipe should pass through it pretty tightly.
It would be possible to bring the stove forward but you may have to increase the size of the hearth......you would also need two 45degree bends to accommodate the flue which may encroach on the available space.
John
