- Joined
- 11 Jan 2004
- Messages
- 47,070
- Reaction score
- 4,080
- Country
That's what I said to my bosses. But apparently, they are confident fault finding can be done in full on a dead circuit....
They came the other day to change bulbs in a few lights and swapped a few electronic fittings for ones with starter
I think the environment has a lot to do with it, I personally don't see the point in working live unless there is good reason for example take an interlocking panel with 50+ interposing contactors/relays, turn the power off and they all drop out. You'd need to check each contactor/relay and all of their control circuits to find out which is causing the interlock to open which is a nightmare of a job, whereas with it live and taking the correct precautions it is pretty streight forward.securespark said:That's what I said to my bosses. But apparently, they are confident fault finding can be done in full on a dead circuit....
A couple of the 2D round fittings were already switching ones. But they swapped a couple of HF 5 footers and replaced with switching.Pensdown said:They came the other day to change bulbs in a few lights and swapped a few electronic fittings for ones with starter
Can you still use switched start in commercial premises? I though they had to be HF
Pensdown said:Can you still use switched start in commercial premises? I though they had to be HF
JohnD said:securespark said:That's what I said to my bosses. But apparently, they are confident fault finding can be done in full on a dead circuit....
I suspect they are also anxious that the widows don't claim compensation saying "but they allowed my husband to work on live circuits"
They need to demonstrate that they don't allow it.
securespark said:The only thing allowed live is testing, but not the likes of changing a switch, mentioned earlier.
Spark123 said:If they want the job done correctly, safely and within a timescale I cannot see a reason why a fully trained electrician with the correct safety precautions can't work live. How can any boss expect anyone to work to BS7671 (including doing the live checks) if you are not to work live? My point is certain things do require working live, however just because I can't be bothered to find the fuse is not an excuse i.e. the live working must be justified.
Work on or near live conductors
14. No person shall be engaged in any work activity on or so near any live conductor (other than one suitably covered with insulating material so as to prevent danger) that danger may arise unless-
(a) it is unreasonable in all the circumstances for it to be dead; and
(b) it is reasonable in all the circumstances for him to be at work on or near it while it is live; and
(c) suitable precautions (including where necessary the provision of suitable protective equipment) are taken to prevent injury.
