Giving it a Henry hoover isnt a service but most customers think thats all your there to do and panic if your not givin it a shake `n vac .Dont even get me started with BG
...So one would expect a strip down of the appliance, burner out etc, also gas analyser test, gas rating, working/burner pressures and general inspection of condensate traps and other inner workings, then? At least an hour? are we all agreeing a service on a boiler should take that long at least?
I believe these were your words....At least an hour? are we all agreeing a service on a boiler should take that long at least?
The older you get the harder it is to climb into loft to pish in the tanks
Just check the bedrooms upstairs, good chance you will find a vase you can use.The older you get the longer it takes to climb into loft to pish in the tanks
I, on a service, perform analyser reading first. Then follow my own service criteria, reassemble and perform second reading along with gas rating. This can take me upwards of an hour on some boilers and alot less on others.
I await an appology from a man![]()
Thank the lord it's not racist as well!!![]()
Im finding your appology slightly offensive and somewhat sexist.
