Replacing Imperial Radiators
25 Sep 2009
Essex
My husband has removed two imperial sized radiators and is hoping to replace them with metric sized ones. Obviously these are going to come up slightly short.
Am i right in thinking it is as simple as purchasing extensions and fitting them to the old pipework and then to the new radiator and this will work?
also are the diameters of the pipework likely to be standard? (if this makes sense)
also do we need to drain the central heating system before trying to put a new radiator on?
you'll have to excuse my ignorance - i'm no good explaining all this sort of thing, although any help would be greatly appreciated!
thanks
yup i would replace the valves as well but thats your call
yes
not if your not going to change the valves and they hold water
you have explained it well enough
and remember
we all have to learn :wink:
thankyou so much kev!!!
i know exactly how to do it in my head - in practice it'll be another thing though!!! lol
i'm a good project manager though - so will be shouting instructions at hubby and have a plumbers number to hand if all goes awry!!!! hehe
just out of interest - what's the benefit of replacing the valves?
yeh keep the kettle on :wink:
the old ones might well be passing
you could also replace them with thermostatic valves to reg the temp :idea:
and if you do decide to it might be an idea to put some cleanser in the system
if you have imperial rads it must be getting on a bit
(ain't we all :lol: )
you make it sound so easy!!!!
but then i guess it would be to you if you're a plumber!
don't be surprised if i'm back on here, trying to get advice about a rapidly flooding house lol
:lol:
The extensions screw into the new radiators, then the rad valve tails go into the extensions, so in theory you don't need to touch any pipe work at all :wink:
:lol:
A submersible pump is good for that, at least you can keep the 1st floor dry.
Until it gets in the sparky bits :roll:
Don't Myson still make imperial sized radiators?... Just thought that it might life a tad easier.
yes they do - but haven't located anywhere that sells their imperial ones
i need
600 x 1170
600 x 1275
600 x 1330
600 x 1550
hence the predicament i'm in and why we're going to change to metric
