Convert fused connection unit (FCU) back to normal socket
6 Dec 2009
Manchester
Hi
I just moved into a new flat and there are two storage heaters. Both heaters are connected to a FCU socket. They are supposed to charge energy during the economy 7 period; however, I found out that they both connected to the wrong socket and charging heat when I switch them on. I only realise this happen when I recevied my last quarter electricity as I switched them on 24 hours a day.
I want to install a time switch to both heaters, so that they can charge energy during nighttime. I just wondering that can I convert the FCU switch back to normal socket and install a 3-legged plug to the heater? so that I can connect them with a digital timer.
Park
Sorry forgot to ask, are either of the heaters in a bathroom?
Mark, thanks for your reply. They are not for bathroom.
In addition i think the 7 Day Fused Spur Timer is too expensive. If it is safe to do so, I will convert the FCU to a normal socket switch as it is much cheaper. I just wondering what is the difference between FCU and a normal socket switch?
nope, that is a MCB, an RCD is very different, a MCB protects against overload and short circuits, a RCD protects against earth leakage.
Does the original FCU have RCD protection? In addition both the socket switch and the plug for heater are earthed. Why I need the RCD protection for the socket switch?
