Hi guys
I need to replace a section of damaged cable outside in the garden. The damaged part is in the ground so I am going to add a junction box on the route and run a new length of cable (connecting at a new junction box). Currently the cable runs in 20mm conduit along a wall, through a 90 degree elbow, then down the wall into the ground. I would like to replace the 90 degree elbow with a junction box so I can join the cable here.
The following has a rubber gasket between the lid and box but I don't think it is suitable for exterior use, am I correct in my assumptions?
http://www.screwfix.com/prods/81094...onduit/Rigid-Conduit/Terminal-Box-Angle-Black
If not, what do I need?
Thanks guys
Thanks guys
