This has most likely been answered countless times before, but I'm looking to clarify the simplest way to replace a plastic light switch with a metal one.
The current set up is a wall mounted plastic faceplate which I intend to replace with a flush brass plate. Behind the plaster, the metal conduit is acting as the earth which is attached to a small round, metal, mounting box.
In order to safely earth the new faceplate will I have to replace the round box with a new square mounting box which is attached to the conduit or can an earth wire be attached to the terminal on the switch and subsequently attached to the round box/conduit?
Obviously i'm looking for the least amount of mess etc as i've just re plastered the walls.
Any help would be appreciated.
Thanks.
Thanks.
