- Joined
- 28 Apr 2004
- Messages
- 8,401
- Reaction score
- 992
- Country
Still be live if it came through the bottom
Err can you run a live sub main cable through a distribution board?
ricicle said:Umm - how else does it reach the main switch and can you supply a regulation number that prevents it ?
Fiardor said:Regulation? yeah probably could if i had the time and inclination to look.
Are you saying that you would happily work on your fuse board the way it is in the photo with just the main switch off?
Pfft. I wouldn't.
Please tell us then what you would do, if there was no isolation device anywhere between the board's main switch and the cutout(s).Are you saying that you would happily work on your fuse board the way it is in the photo with just the main switch off?
Pfft. I wouldn't.
I agree totally. In common sense terms, it's ridculous to waste time even thinking about it.There is a minimal chance of cable overheating, when using cable ties, which is why it's not a great concern.
No-one has suggested that it's not allowed - grouping of cables is, in general, always allowed. However, the regulations do require that, when cables are grouped (with no common sense qualifications/exceptions to the requirements being stated in the regs) a grouping ('de-rating') factor be applied when working out the maximum permitted current carrying capacity of the cable. If the Iz of your tied cables are adequate, after allowance for grouping, then the cables are compliant with the regs, as well as obviously being OK in common sense terms.Which regs are you reading to determine that this practice should not be allowed?
Kind Regards, John.
No specific reg against it, but its a sign of bad planning and bad workmanship.
Again I will ask the question - what is the danger from the cables entering from the top ?
To the best of my knowledge, as far as the regs are concerned, grouping is grouping. In fact, give that (as I assume you would agree) a number of cables arranged side-side count as 'grouped', I would have thought (from thermal considerations) that arranging them in a 'bundle' secured by a tie would be considered to be at lead as 'grouped'.Where did I ask why grouping isn't allowed? I asked why you think that the practice of using ties in this manner is not allowed?
As I keep saying, I agree totally with that common sense view.I take the view that this 'grouping' carries as much risk as that where cables enter enclosures. The assessed risk of overheating is low.
I think I've already made that observation. The regs really ought to be much clearer in defining the extent of 'grouping' that requires cable de-rating.Taking your argument further would mean practically every circuit would require the CF.
I wouldn't expect any sensible human being to have a problem with the practice. However, in terms of the regs, I have to ask again .... where does BS7671 say that, when common sense suggests that it's OK, one can ignore the requirement for applying a de-rating factor for grouped cables (and/or deem a number of cables tied together as 'not grouped')?The IET chaps don't have a major issue with this and I phoned the technical helpline last night and they don't either.
True, they don't mention this particular situation - but nor do they mention hardly any other particular situations, either.The regs don't define whether or not) this practice is to be taken as grouping cables.
As I've said many times, that is the view which almost any sensible person would take by application of common sense. However, as we all know, common sense and regulations do not necessarily go together.However, for practical purposes, some of us take the view that it's not a concern.
I'm not really sure what aspect of the situation we're discussing that makes you feel that this may not count as grouping - is it the short length of the 'grouping', the fact that it occurs inside an enclosure, or what? I presume that, in most situations, if there were a number of cables bundled together and held with cable ties, you would regard that as grouping?
Kind Regards, John.
Yet again, we are all agreed that this is the reason why sensible people would not regard it as a concern.The risk is low and it is a combination of the length of the grouping and the fact it is inside an enclosure.
