How many RGI's here Do their own electical Work.
Status
Not open for further replies.
Bottom line, what are you trying to achieve?
answer?
That all RGI installers must be Part P registered to do their own electrical work.
Simple.
what about commercial ones?
You can change like for like.
Or just stick a plug on the end.
Fixed equipment must be wired to a FCU (BS7671)
Manufactures instructions also denote fixed equipment MUST be wired to a DOUBLE POLE Fused Connection Unit. How does a plug top possibly comply?????
A plug is fine, now who should read the regs.
1) You because you are wrong!
Sorry Vic doitall is not wrong, you are
a few points to note
1 connection via an unswitched socket is perfectly acceptable
2 MI's take preference over BS standards anyway (its called passing the buck)
3 how does a DOUBLE POLE socket outlet not comply?
now don't tell me you didn't know you could get them
Matt
answer?
Simple.
Matt
1) not its not it contravenes BS7671 regards fixed equipment read it NOT the MI
2) Not true
3) Read point 1
manufacturers instruction are the "bible" for installing gas boilers, now please stop digging or at least post something to back yourself up.
<yawn> bored, seems like just another crusader p1ssing in the wind. As much as the sun sets and moon rises. The freaks rattle their chains.
I did earlier, its called the Part P document of the Building Regulations.
I thought the gas regs were
No.. MI's are...
Anyway, I need to get back to my wiring diagram... Gotta teach an underling how to do an S-Plan through an RF2 pack 4 tomorrow.
Let us know when you have clarified things with GSR.
MI overule ang gas safe\building reg etc as they have been deemed acceptable. call gas safe with an issue and all yiu ver get is consult mi, not sure if spark is the same but for gas mi overules everything
MI tell you to obey BS, why can't people understand this???? They specifically mention BS7671 must be adhered to and yet not one person here appears to be knowlegable of the publication and yet spend nearly 3 hours arguing with me on the very same subject!
Status
