Not that one, its a temp prob of a instrument
Your traditional thermocouple (pilot light) isn't connected to a switch either.
That's wierd because I wire up loads of heating systems for a local plumbing firm, and it's always just switches.
Possibly on paper - you- but in the real world u arnt allowed inside them and as a NTC is now deemed a switch I think u best leave the pumbs to fix them!So who is most qualified to change electrical componants on a gas boiler?????
Can use switch as an option but not standard fitmentThat's wierd because I wire up loads of heating systems for a local plumbing firm, and it's always just switches.
Room stat = switch
yes switchFrost stat = switch
No can't use switch has to be special to match boilercylinder stat = switch
Part of boiler so not really wired by electricianlimit stat = switch
programmer = switch(es)
Since when come on that's never been a switchthermocouple = switch
I went to the trouble to post links to the PDF files as to be frank I was surprised as most I have wired did not have the programmer built into the boiler.NTC = switch
zone valve = switch
Yeah there might be some fancy electronics in there but all it really boils down to is lots of switches
The surprising thing was the temperature BS7671:2008 tells us 70 deg max for anything not hand held but can be touched made out of metal but this boiler went up to 90 degs clearly not complying with electrical regulations if used with steel radiators unboxed
A valve....
Would you call a ball cock a switch?
I think the problem is to reduce radiator size you need to raise the temperature and with a closed system there is little to stop one running at higher temperatures.The surprising thing was the temperature BS7671:2008 tells us 70 deg max for anything not hand held but can be touched made out of metal but this boiler went up to 90 degs clearly not complying with electrical regulations if used with steel radiators unboxed
Just about sums it all up ! Left hand never knows what the right hands doing. Very good post mate, A voice of sanity!![]()
