That wouldn't be the reply if people only asked DIY questions instead of -(IE get an electrician in!)
Can the powers that be take the electrics uk section off this site as it is pointless as I can answer every question as well as everyone else (IE get an electrician in!)
I suggest you get an electrician in, to answer that!Can the powers that be take the electrics uk section off this site as it is pointless as I can answer every question as well as everyone else (IE get an electrician in!)
...I am getting an electrician to do final connections but just want to do donkey work myself to keep costs down.
and from this people could reasonably deduce that you did not have the faintest idea of what you were doing.... I have a 63amp 3 way consumer unit which is powered by a spur from the household socket ring which is from a 30 amp fuse in an old fuse box.
Firstly is this ok..?
Better than none, then.Must be the most unhelpfully section on here. With the most arrogant members.
However there are a few pro's that are very helpfully.
It was not possible to do what he wanted with what was there.Look at the neon light switch thread. That sums the whole attitude to this section.
Depends what you mean by simple but not really.Yes a simple task.
Would "You will need to completely rewire it" have been considered 'helpful'?the guy could have been given more help.
And now he actually knows what to do.Instead he had to go and research and find out the info he needed elsewere.
