I apologise for missing that rather odd point. I'm not good at thinking like Joe (middle name Moron) Public.
You don't want to be 'normal' these days.
I don't want to be 'normal' ever. It's boring.
Well - In general household use there aren't that many different sized flexes in use.
Small items and lights will have 6A flex (no derating) so 3A is fine, (5A will also do but most people won't have any).
The next step up will be appliances with 13A flex.
ok an example
650w microwave with 3 amp fuse goes wrong not a dead short but severe arcing the fuse will blow in a short time
same scenario with a 13 amp fuse drawing approaching 20 amps for a short while is going to cause a lot more damage unessiserily
i really find it stupid when 1/3/5/10/13/15 ARE AVALABel
230 x3= 730wA 650W microwave will not run on a 3A fuse..
yes i understand iff the output is 650w the input will be nearer 900-1000w
i must admit over the 15 or so years i had it did blow 2 or 3 fuses
as you know you have to vastly overload a fuse for it to blow or run it fairly constantly at around 25% over to blow
Err...you certainly wouldn't design a circuit like that
Put a 5A in then.but we are talking about the safety device here if you can match the device closer to the operating characteristics off the fuse you have a win win situation as a 3 amp mains fuse blowing has no operating dangers like exploding and causing damage
Circuit design entails having a large enough cable to carry the load demanded and the cable protected by a device rated equal to or higher than the load but lower than the maximum current carrying capacity of the cableyou certainly wouldn't design a circuit like that
That's because you are thinking that the fuse is there to protect the appliance.i consider my choice off using as small a fuse as possible as the safest option
Well, you wouldn't - the fuse blew.i have never ever noted any damage or overheating smells whilst running any item or changing a blown fuse
Apart from the fuse blowing - because it was too small (if that's what you mean).in other words everything worked and appeared normal
It is unnecessary.can anybody tell me what i am doing is other than sensible and safe and why
