Getting down to basics, the citizen's job is to call for the Government to protect us from unscrupulous traders, not to tell them exactly how to do it. It looks to me as though Trevor Ord has done a pretty good job in what he has said. The e-petition system only allows a fairly short statement, so not room for much detail.
There are a number of ways in which the government can regulate something, for instance pepper sprays and CS sprays are regulated by section 5 (1) (b) of the Firearms Act (1968) which states:
"5 Weapons subject to general prohibition.(1)A person commits an offence if, without the authority of the Defence Council or the Scottish Ministers (by virtue of provision made under section 63 of the Scotland Act 1998), he has in his possession, or purchases or acquires, or manufactures, sells or transfers—
(b)any weapon of whatever description designed or adapted for the discharge of any noxious liquid, gas or other thing;"
No need for a standard there!
(As an aside, it is interesting that, in total contravention of the above, Amazon.co.uk does offer both CS Spray
http://www.amazon.co.uk/KU-24220-KO-Spray-40ml/dp/B001O0DQWO and pepper spray:
http://www.amazon.co.uk/Peffer-KO-Jet-40-Ballistol/dp/B001O0DQTC )
A more reasonable approach with socket covers and other currently non-regulated items would be to bring them within the scope of the plugs and sockets regulations and require them to bear an approval mark from a notified body in the same way that all BS 1363 plugs are currently required to be approved. The regulations could state that the products must conform to the relevant parts of BS 1363-1. The approval houses (BSI, ASTA etc) could be left to determine the dimensional, mechanical strength, creepage and insulation parts of the spec against which they would approve the item. This is not so different from the current practice of the approval houses developing variations of BS 1363 to allow the introduction of the ThinPlug and the SlimPlug.
Although I would agree they are clearly made to plug into a 13A socket they are not electrical and I can't see how one can differentiate between the match stick and and plastic lump. We have all seen the screwdriver being used to defeat the safety shutters be it to push in a probe for a meter or a pair of wires with no plug.
The difference is in the intention of the manufacturer. Returning to the pepper spray comparison, it is not illegal to sell a water pistol and a container of very hot chilli sauce in the same supermarket transaction. But if the supermarket supplies the water pistol filled with the chilli sauce and describes it as being for personal defence, it becomes illegal.
How would you stop these being made illegal:
Or would you not want to?
I absolutely would wish them to be illegal! Nothing which is not made to the correct dimensions of a plug should ever be sold to put in a socket. The skeletal line and neutral "pins" on that thing are clearly not made to BS 1363! Do you have any idea what trying to force one of those into an MK Logic Plus socket, or the three pin shutter operation sockets from Legrand and Hagar, would do to the sockets?
As to the "barriers to trade" issue, as everything under discussion relates to products which only have an EU market in UK and Ireland (and the Irish legislation tends to follow the UK in this area) then it seems unlikely that it would be of any significance. The fact that we use BS 1363 is a much greater barrier to trade than actually requiring accessories for BS 1363 to be safe!
I feel the existing Trading Standards system is more than adequate for this situation.
Having discussed this in detail with trading standards officers, I can assure you that is not the case. All trading standards departments are very over-stretched by local authority cuts. They have neither the time nor the money to be able to bring case where the burden of proof lies with them, as it would be in the case of socket covers. If there are specific regulations they can act, general safety regulations are next to useless, and provide no solution to this problem.
There are socket covers which are ( apparently ) both safe and effective.
The petition applies only to plug-in socket covers. There are no plug-in socket covers which meet the dimensions specified by BS 1363, therefore it cannot be said that any are safe. As to being effective, the only way manufacturers have found to make them too difficult for small children to remove is to make the pins oversize and/or on incorrect centres. That is not an acceptable approach, and is certainly not safe! No manufacturer claims to do any electrical testing, so that does not suggest an interest in safety either. "It's plastic so it must be an insulator" is as far as they go.
However, a regular 13 amp plug fitted or not fitted to an appliance can be inserted wrongly in the same way a 'safety' cover can.
Most plugs will not stay in place in most sockets if inserted in the inverted position. All socket covers will stay in place in almost all sockets in the inverted position. This is mostly to do with their flexibility, and partly to do with their very light weight.
