Soft plastic plug to replace a moulded one
27 Nov 2002
Ireland
The moulded mains plug on our Miele vacuum cleaner got damaged, so I replaced it with a regular one. But it's not ideal, as it's a bit hard and is therefore more hazardous when flailing around during cord retraction.
It could easily mark the wooden floor, or worse, and is likely to just break as they're not designed to be banged around. It's also larger than the slimline moulded plug, so doesn't fit into the retracted cord housing very snugly, which is an issue when the unit is stored stood up on its end.
So what I need a softer plastic plug. In fact, rather like a moulded plug, but one that will allow me to wire it. I can't find one...
A Duraplug is what you want I think.
Or order a new hoover cable with plug, and get the service manual to find out how to open up the hoover to connect.....
Thanks for the replies. The Duraplug looks a little larger than I'd like, but I'll have a look in my local B&Q in Galway to see if they have one.
I got the Duraplug. It's a little larger than ideal, but fits into the recess alright - sometimes some manual reorientation might be needed.
It's a semi-soft plastic rather than rubber, so shouldn't leave marks on the floor. It's more likely to survive a few bangs than a hard plastic one anyway.
