Whilst doing some additions due to building works, came across these 2 pendants. (Photo's a bit fuzzy as taken with my phone camera).
I take it there was no RCDWhilst doing some additions due to building works, came across these 2 pendants. (Photo's a bit fuzzy as taken with my phone camera).
You think so? If so, what would they have been using the black insulated ones for - and why would they have sleeved their neutral with G/Y? ... seems fairly unlikely to me.i assume its not actually earth and someone has used the uninsulated wire for a netural connection.
Doubt it, it will more likely be someone not knowing what they are doing and trying every combination to get it to work.
In a TN system the earth (CPC) and neutral connect to the same place either back at the transformer or at the cutout so it will work (providing there is no RCD protection), it just isn't safe nor legal.
Even with TT, particularly with parallel paths to earth via main bonding, at least a few of those would probably work (at least with incandescent lamps) without people noticing too much reduced brightness - but, of course, with TT there certainly ought to be an RCD - so it shouldn't work!In a TN system the earth (CPC) and neutral connect to the same place either back at the transformer or at the cutout so it will work (providing there is no RCD protection), it just isn't safe nor legal.
True, but I was talking of 'at least a few', and incandescent lamps. Assuming to other L-E leaks, a 100mA RCD (which I guess is, traditionally, what one would be most likely to find in a TT installation) would obviously allow up to 23W total of lamps (connected L-E) without tripping, and a 300mA one up to 69W total.Depends on the rating of RCD, load of connected lamps etcwith TT there certainly ought to be an RCD - so it shouldn't work!
Sure, the sums get complicated, and require data (on voltage/resistance relationship for lamps) that I don't have readily available. However, taking my TT electrode as an example (generally around 75ΩI don't even think you'd get that, given the cold resistance of a lamp is lower than with it hot. Then the rod resistance makes the maths too difficult to be bothered to do![]()
It ain't going to be 'cold', or anything approaching cold, with something approaching 220V (or anything like that) across it. I'll see if I can find some data.iirc there is somewhere around a 10:1 difference between hot and cold resistances hence your 2300R hot lamp when cold is somewhere around 230R
