and it could be reasonably expected that compliance with BS7671 would be accepted as demonstrating compliance with "reasonable provision etc." although it may not be the only means?
Can I ask, what classes as a new circuit? Would extensive modification of an existing circuit count?
No. A new circuit requires a new protective device. Even if you connect into an existing circuit at the protective device it is still not a new circuit.
Anyone who thinks differently doesn't know what a circuit is.
Wiring into empty MCBs would count as new circuits !
Ask them for prove the MCB were empty before![]()
That's my thinking. What's to stop a DIYer to have the cu installed with a full set of MCBs, wired to terminated short twin and earth of an appropriate csa, then subsequently "modify existing circuits" by adding to the wires using either crimps or appropriate maintainance free jb?
This seems to be, ahem, legit, as long as it doesn't route through special locations?
I think you can include the shower as well !So from 6 April a DIY'er could rewire a house (minus a shower) without it being notifiable provided you don't need a new Consumer Unit or need to add an extra MCB?
Replacement is the clue.The next question that then arises would be whether replacing the shower unit with a different make/model but similar specifications would be classed as an alteration ?
There is no mention of the oft-quoted 'like for like' in the regulations.
Incidentally, this is the case at present.
