That was strictly for safe tea making proceduresGiven that we've been talking about those posts which don't say quite what we intended, did you really intend what you wrote here?![]()
Yes, we know your view, but we have to function in the real world. In practice (since it is 'inevitable', even if we don't like it), your third statement would apply in a high proportion of cases. If that were to become the standard response to almost all questions which get asked here, one might just as well close the forum and replace it with a statement ... or, if it would give you satisfaction (that you were performing a public service) we could just leave the forum to you, to cut/paste that standard response whenever anyone posted a question.Never, never regard that as acceptable or inevitable.we all know that a high, probably very high, proportion of DIY electrical work actually fails to comply with Part P because of the absence of appropriate testing. However, given that that is almost certainly never going to change (no matter what we say to DIYers), I'm not sure what we can/should do about it, or what attitude we should take to it.
Always, always tell people that they must test.
Always, always tell them that if they cannot or will not do the work properly then doing it improperly is unacceptable - it is simply and clearly "do it right or do not do it at all".
It's sad, but true. Good luck with your campaign, the concept of which I fully support.Indeed we do - your attitude is shameful. But there you go - the world is full of people who dress up defeatism as pragmatism.
Chapter 61, 62 & 63 quite clearly states it, approved doc part p states it,
If you care to read them?
That's all correct, but the reality is that for the great majority of people (including the vast majority of DIYers), being able to show that they have complied with BS7671 is the only way that they can support an argument that they have complied with the law (i.e. Part P of the Building Regs). Only someone with considerable expert knowledge would be able to even attempt to argue that they had complied with Part P even though they had not complied with BS7671.I think you are referencing the British Standard and the Part P guidance? Part P is part of the building regulations. It is law but only states: .... It does not reference the British Standard. The approved doc does reference the BS but is guidance not law.
No need to go over all this again though
Yes, do you have an answer?You mean reasonable provision?
Lets hope your not the first then!Has anyone been taken to court and tested what the court would accept as "reasonable" apart from compliance with the BS?
Which will be detailed on the documents on commissioning.Worth remembering that the BS changes and that non compliance with the latest is not going to mean that the work is dangerous.
Your to blame then!What have I started...![]()
I thought mine was clearer and preciseIt was a simple query, and as John clearly stated, my example that he addressed would not be notifiable but there are clear exceptions which we can all refer to via the formal documentation, if interested.
It is not sad at all, it's a forum that opens up discussion between all types from all walks, with a varying degree of knowledge, experience and skills. Providing no one is abusive and aggressive long may the ship sailThis forum sadly very often goes off track, turning a simple thread into a realm of confusion for anyone else referring to the topic at a later date.
That is the problem, there should now be no grey areas, they have had long enough to sort this out, opinions apart!Can't we just all accept that we now know the implications of the 6th April changes, and that our own opinions are exactly that, our own?
I'll give you that one, providing you can prove with documented evidence, that the installation and fabric of the build was no worse than when you started the work. All structures are compliant to building regulations, you have performed, all plumbing was compliant to water regulations and part G, L and H of BR, visual inspections and soundness tests using hydraulic pressure testing of 1.5 of normal working pressures on rigid pipework, 1/3rd on plastic pipework, taken flow rates, pressure and temperature readings of water and heating systems, performed seal loss air tests on sanitary appliances. Followed the requirements of BS7671 when installing electrical systems, performed I,T & C as chapters 61,62 & 63 of BS7671.And I will add that accredited or qualified doesn't necessarily mean that a job is actioned any better than that of a competent DIYer - I have seen 'professional' work in many of the trades (building, tiling, plumbing and electrics) done to an appalling standard, far lesser than the work I have done myself, as a DIYer.
If not get your cowboy boots onYEEHAW
