Google wrote
The cooling effect of sulphur pollution on climate has long been recognised by scientists studying volcanic eruptions, which have, for example, caused failed crops and famines in the past. Sulphur dioxide forms droplets of sulphuric acid in the stratosphere, which increases the reflection of the Sun's heat back to space, cooling the Earth's surface.
The effect also explains the lack of global temperature rise seen between 1940 and 1970: the effect of the sulphur emissions from increased coal burning outpaced that of carbon emissions, until acid rain controls were introduced, after which temperature rose quickly. Some have even proposed sulphur dioxide could used to geoengineer the planet by deliberately injecting millions of tonnes into the atmosphere to combat warming.
Go on then, one is on the surface the other is thousands of feet up.
This is all fancy words designed to impress and to try and explain away inconvenient date. What it translates to is; 'like the rest of us, the scientists haven't got a clue'
Yes but does the ice cap melt dictate the jet stream or does the jet stream dictate the ice cap melt.
The climate has been going up and down for millenia. Remember in Egypt, they had the 'seven fat years and seven lean years'.
I bet they weren't grumbling about climate change then.
Oh yes, and the Romans had vineyards in this country.
It was predicted last September that the winter would be a very long one and they got it right.
But did the poles melt over a few decades? No.
