I'm turning my phone off just in case!
It's a worry when you realise this, but your electrician clearly doesn't!
I'm turning my phone off just in case!![]()
So are you still going to pay the lying, thieving, dangerously incompetent c*** who has perpetrated this mess on you?I have a trusted electricians phone number who I will call tomorrow.....
I'm sure he does.when I questioned him I genuinely believe he thinks this is OK......
Has he?On the circuit side he has put 2 x A3 radials in
Not helpful, but anybody who works on a circuit without checking for dead using a proper 2-pole tester which they know is working OK deserves anything they get if it is not dead.But he has also left the socket by the back door on another circuit….so someone working on this house may think they have isolated the kitchen circuits where as one would still be live!!! He has clearly labelled the CU with kitchen sockets…..
They should all be Wylex.I think he has switched to the other type mcbs as the lighting ones are wylex…..I should have taken a picture before to be sure!!!!
You must then have another CU somewhere, because there are no 20A breakers in the one you have shown us.
Either that or he is not telling you the truth.
"A3" is the term used to describe a 20A radial. Where the regulations come in is that you can't have a device rated at more than 20A if you use 2.5mm² cable.OK so by definition an A3 radial must be fitted with 20A breaker, and this would be regulation?
YouThe idea was all the sockets in the kitchen were meant to be on a ring. NOT on a load of heath robinson radial mish mashes.
Are you absolutely certain that those two 'radials' aren't joined, creating a ring? Do I also take it that the wiring is all in 2.5mm² cable? If so, those two radials on a 32A MCB are seriously non-complaint.1 radial circuit containing 3 x twin 13A socket joined in junction box to 2 x twin 13A sockets + 1 x switched & fused extractor hood. ... On a separate radial circuit 1 x twin 13A socket. .. These two radial circuits are wired to 1 x 32mcb labelled 'kitchen sockets'
You could invest £10 in a multimeter from Maplin to check continuity.
And before you get the other spark in, you sure you don't want to further a complaint with the NIC??
Because once you get the other guy in, the NIC won't entertain a complaint.
