- Joined
- 11 Jan 2004
- Messages
- 46,516
- Reaction score
- 3,817
- Country
What I meant to say is that I read it as 300mm and couldn't see what the joke was!!
I know that's what you meant to writeWhat I meant to say is that I read it as 300mm and couldn't see what the joke was!!
Has he re-educated himself, then? I thought you said that he was previously adamant that everything he had done was 'right'. If so, I presume that he will only be able to "get things (really) 'right' " if he has now learned what (real) 'right' actually is.Sparky mk1 is coming back to do things properly. So he is not all bad, he was very apologetic, and wanted to get things right.
What's he going to do with the CU, vards?
Whilst that is true (and desirable, and surprising that it has not been done 'properly'), since the installation has not been subjected to a 're-wire', I doubt that there is a requirement that it be brought up to compliance with current regs as regards separation of circuits, is there?A new consumer unit, or a complete overhaul of the existing unit replacing the RCD for a main switch, and all the circuit breakers for RCBOs is the only way this installation can be brought up to compliance with the regs.
