Aah, so effectively a fuse in the neutral then..I'm just being impish.
I suppose so. However, as I said, it doesn't seem conceptually all that different from a 3-phase situation - if protected by fuses (rather than some sort of breaker, which would have 3 linked poles), one (or two) of those fuses can operate, still leaving a potential relative to earth on two (or one) of the conductors ... which has much the same implications as a neutral fuse operating in a 2-wire situation, doesn't it?Aah, so effectively a fuse in the neutral then..I'm just being impish.
Quite so - but call it a '2-phase supply' for that reason and you'll probably end up (yet again!) with a few pages of argument - even though that's what BS7671 calls it!Another way of looking at it is as 2 phases at 180deg
Do you have any proof of that?the guy I bought it off said it would be just plug and play with a converter.
In what sense is one of the connections to the Appliance a "Neutral"? I thought that (not unreasonably, IMO) the definition of neutral required that it be connected to earth somewhere - usually (always?) at the source (and sometimes also other places, as in PME).It quite simple if one accepts that a wire can be Neutral at one end and Phase at the other end, Or more precisely
Neutral ( Appliance UK 230 volt ) can be connected to a Phase ( Supply USA 110 volt )
Live ( Appliance UK 230 volt ) can be connected to another Phase ( Supply USA 110 volt )
In the sense that the manufacturer labels it as Neutral because in the UK almost every appliance requires a Neutral and a Phase ( Live ) in order to have a 230 volt supply.In what sense is one of the connections to the Appliance a "Neutral"?
My understanding is that Neutral is the mid point of a multi-phase distribution system where if a multi-phase load(s) is evenly balanced across the phases then no current flows along the Neutral.I thought that (not unreasonably, IMO) the definition of neutral required that it be connected to earth somewhere - usually (always?) at the source (and sometimes also other places, as in PME).
We need a referee, then - maybe my 'understanding' is incorrect. I agree that the neutral of a multi-phase supply will be as you describe, but I thought it had to be earthed. Are you suggesting that a true single-phase supply cannot have a 'neutral', even if one side of the supply is earthed at source? BS7671 certainly acknowledges the concept of a single-phase 2-wire distribution system with conductors labelled as L & N - if there was not a requirement for the N to be earthed, how would one distinguish between L&N?My understanding is that Neutral is the mid point of a multi-phase distribution system where if a multi-phase load(s) is evenly balanced across the phases then no current flows along the Neutral. There is no requirement for the Neutral to be earth for the system to work as a supply system.I thought that (not unreasonably, IMO) the definition of neutral required that it be connected to earth somewhere - usually (always?) at the source (and sometimes also other places, as in PME).
I should perhaps also have commented on this. It seems to be a bit of a vicious circle - as you imply above, if the supply were not earth-referenced at all (i.e. totally floating wrt earth), there would not really be any need for any safety devices to operate in response to a single fault (between one phase and exposed-conductive parts). The argument for earthing could be in relation to the (very low) risk of two independent faults (both phases having faults to different, simultaneously touchable, exposed parts), particularly given that, in the absence of protective devices, the first fault would probably go unnoticed, and hence would persist. It may also be impractical to ensure that a supply is, and will always remain, floating relative to earth.There is no requirement for the Neutral to be earth for the system to work as a supply system. The Neutral is connected to earth to enable safety devices to operate when there is a fault. ... If the network Neutral was not connected to ground then the risk of electric shock would be reduced as there would be no return path.
Indeed, although the hypothetical system to which I was implicitly comparing would, I suppose, be "II".Hence the problems and restrictions around IT systems.
