Neighbour has two separate augers in his milking parlour and each are controlled by a timer relay switch that are set for 10-15 minutes. One auger is always having problems with the time switch and it has been replaced twice already and has failed again. Seems to last 3 months at most.
The auger works by a switch inside a bin and when the bin's contents drops below the switch, the switch goes into an on state and every 15 mins etc the timer/relay starts the motor if the the switch state in the bin is on. If the bin is full, the motor doesn't start.
Can anyone recommend another timer relay to use just to see if that one is far more reliable?
Because the other auger works fine without issues, could the DOL-Starter on this one have some sort of impact on the timer relay packing up?
Thanks for any input.
View media item 85954
http://www.milkingmachines.co.uk/pdf/Relpol_Multi_Timer.pdf
