Re-Fitting my en-suite
23 Feb 2012
Cambridgeshire
We moved house just under a year ago (the house was built in 2004), since then it seems other than painting the walls, nothing in the house has been changed.
The en-suite to the master bedroom had plain 6inch x 12inch white tiles around the shower tray and just above the sink which were uninspiring to the eye and looked a bit grubby.
For the sink area, there was a custom built unit built that was constructed using a couple of kitchen cupboard doors and chipboard formica worktop. There was a counter sunk sink (that had a huge 4inch scar in the enamel finish!).... Simply put, it looked pretty bad, unfortunatley I didn't take any "before" photos so you'll just have to try and imagine what it was like using my bad description ;).
On the new suite, we decided to go for a timeless luxury look with some modern elements rather than going bang on trend and getting fed up with it a few years down the line. So here's a little bit about the work I've done along with photos that could be useful to someone else wanting to do a similar project....
After ripping out the old "suite" & removing the stud wall dividing the shower and basin area...
The master bedroom was a mess (it's the next room to be sorted)...
Re-Boarded the walls & plastered the ceiling...
Re-routed plumbing for the shower:
Fitted the shower tray (re-inforced the flooring by installing new joists under tray area & bedded tray - using a 5:1 mortar mix - on top of ply board).
Added a small shelf into the stud wall to avoid having to use a metal hanging "thing" to hold shampoo's etc...
Quick test fit of the shower:
Re-routed the plumbing for the basin and boarded with ply as I'm going to use a floating sink unit that hangs from the wall so ply is far stronger for holding it solid...
Getting the room prepared for tiling; had to remove the radiator and free the heating pipes as I'm replacing this with a heated towel rail...
Decided to mitre cut my way round the 90degree angles avoiding tile trims:
Fitted mosaics to the back of shower wall, shower shelf wall & behind the basin....
Started tiling the other walls...
Need to finish the tiling.... will update next week.
nice. you seem to have used normal plasterboard around the shower. If so, I think that was a mistake. If I am mistaken I apologise!
Indeed, but I saw no mention of that either :)
You're quite right; I didn't explicitly mention that I'd tanked the shower; in my defence it's fairly clear from these photos (if you know what you're looking at) that tanking was done for the shower area; tape on every join and walls covered with grey tanking paint...
wow, great work! I wish I was brave enough to have a go at something like this. Enjoy your shower :P
I was away skiing for a week so I missed the last couple of weekends in mid-feb hence no updates, but over this weekend I painted the ceiling and replaced the radiator valves (sorted the plumbing so pipes would fit behind tiles). I also finished sticking the last few tiles to the walls, did all the grouting & fitted a new extractor fan.
I need to finish polishing up the tiles (removing the last bits of grout haze) after work this evening, but here's some photos after this weekends work....
Looks great,
Although this would bug me like crazy that the tiles aren't following the pattern, I see why you did it though.
so will everything be completed once the tiles have been polished, or do you have more plans?
