A voltage drop in a junction box means heat is being created in the junction box.
Thank you for this answer - I'll interpret this as meaning there is no voltage drop from a junction box unless it is not wired correctly and is creating heat.
I've managed to eliminate two junction boxes from the design so far. I'm going to keep trying to eliminate more.
Future sockets I will definitely strip more grey insulation as advised. I was trying to leave as much protection as possible. If stripping more grey insulation is the done thing then it makes my life easier too.
Is there anything I've described doing so far, which someone believes may not be to code?
