I don't recognise the Proteus, but it is important to know that unlike MCBs (which you can switch on and off under load), with fuses, you must turn the main switch off before inserting or removing them. Otherwise there may be quite a big flash and spark.
It might be worth making a label to fix to the CU saying so. If they do hold cartridge fuses, get at least two of each rating and leave in a clear jar or plastic bag where they are visible and easily accessible. The reason for "at least two" is that sooner or later you are sure to change a fuse but the fault will still be present.
