There are so many issues and things that are missed, I am surprised this guy is still being allowed to look at the boiler
1. Leaking flue should be looked at immediate and appliance not used until flue secure. The flue clamps have two holes- take it supplied screws were fitted so that clamp would not come apart. Does the flue have stipulated slope in it? Take it the entire flue length is properly supported. Is the 5 meters of flue straight run or are additional elbows fitted in line
5. Chemical flush can take several days to suspend the system debris for final removal, which itself warrants several flushes. To use a chemical to clean the system, then not remove it as per the manufacturers instruction- well might as well not do the chemical cleanse as will not make any difference. Some chemicals if left in the system, will cause problems not dissimilar to your issues. If pipe sizes are a problem, if I was the customer, I would have expected to be told beforehand, not afterwords. Where there issues with previous boiler?
6. If he is not registered, he cannot fit a gas appliance. If someone else signs his work, he is also leaving himself open for prosecution.
I would approach the guy who signed the work off and talk to him. If no joy, I would be talking to gas safe as there are some basic safety issues with flue system. It is better him reported for unsafe work practice than him killing someone
I do not know what made you go with this lot for boiler replacement, but if it was based on the cheapest bottom line and no additional research, then you have got what you expected- cheap and nasty installation.
Final thing you have to ask yourself, when the boiler breaks down, are you going to get this installer back to effect repairs? If yes, and he needs technical advice from Vaillant, how is he going to get it with a Gas Safe number
