You need a multimeter!
I can guarantee there is no separate fuse for this light, the fuse box is pictured and all switches are up, therefore it appears likely that the previous light holds the key to the problem, is this likely to be the lounge light?OK. I stand corrected. The first picture of the rose did not tell the whole story.
This is a loop in system, where all the connections are available at the ceiling rose.
Likely, either this light is on its own circuit and the fuse has gone or, as Echo has said, the feed has gone open circuit at the previous ceiling rose.
I am unsure as to what exactly the breaker connects to as this is what was here when I moved in, it appears to not be connected to anything in the kitchen or indeed to any sockets at all that I can find, turning it off does not affect anything inside the house,Difficult to say.
Why have you got a kitchen socket on a 6A breaker (unless it is a 5A socket)?
