Next I expect you will be telling us you have been a plumber for 20 years so you know it all.
Dan Robinson, I thought you would respond as such.Congratulations on your 17 years which has proven nothing. I have proven I know more about the Systemate and how it works than you for certain.
Bernardgreen, Neat. What temperature do you set the cylinder at? Does it need a thermostat blending valve? on the shower and/or the normal hot water pipe from the cylinder?
No I do not. I have a shower with full mains water pressure.bernardgreen, you have an old setup that needs one of those awful, noisy, leaky, power shower pumps to avoid running around the shower to get wet.![]()
The green / orange "box" in the top of the cylinder is a "coil" with a large surface area.
bernardgreen, apologies, well it does not look like a coil. Neat. Did you have this custom made? I remember seeing these for sale a long time ago. What is the performance of the shower? Can it do two showers? What temperature do you need the cylinder set to?
Oi BG, does your C/Heat F&R connect to your sludge bucket?
Could this be the reincarnation of Doctor Drivel, Big Burner, Water Systems etc etc etc???!!!
It is not a sludge bucket, flow and return do connect to the coil in the bottom of the cylinder to heat the water.
Could this be a reincarnation of Sir Richard Puller von Hohenburg, died Zurich 1482
If I was putting the design out to an installer than there would be a full set of drawings and not just a rough sketch. That said I woud have expected an expert in heating to have been able to interpret that sketch using his or her experience and knowledge.miss half the details from the drawings & leave the installer to guess the design!
