Clever clogs!Dunno. Is it type-tested to EN 60439-3?
How about "consumer unit"?i hate to join in, but what's an enclosure that contains MCBs and cartridge fuse carriers in one called?
Why not?p.s. you should NOT really have MCBS and cartridge fuses on the same din-rail
Why is it always so?it is unnecessary to mix and match
Don't be ridiculous. Even though you can't help it.it just looks so Awful!
Yup - these would look ghastly next to each other, wouldn't they.it just looks so Awful!
Or even BS EN 61439-3 nowadays...Dunno. Is it type-tested to EN 60439-3?
and you don't think fuse carriers and MCBs manufactured in the same range by the same manufacturer are not type tested? Come on! You cannot believe that to be trueType Testing is the answer for Ban!
They will, but there are other reasons for installing fuses instead of MCBs.If a correctly installed CU, has a breaking capacity of 16ka, surely breakers alone will comply,
Maybe, if type-tested as an assembly.How about "consumer unit"?
