The 17th Ed. defines consumer unit thus:
Consumer unit (may also be known as a consumer control unit or electricity control unit). A particular type of distribution board comprising a type-tested co-ordinated assembly for the control and distribution of electrical energy, principally in domestic premises, incorporating manual means of double-pole isolation on the incoming circuit(s) and an assembly of one or more fuses, circuit-breakers, residual current operated devices or signalling and other devices proven during the type-test of the assembly as suitable for such use."
The 16th Ed. did not have a definition for "Consumer Unit".
But it did have this:
Distribution board. An assembly containing switching or protective devices (e.g. fuses or circuit-breakers, associated with one or more outgoing circuits fed from one or more incoming circuits, together with terminals for the neutral and protective circuit conductors. It may also include signalling and other control devices. Means of isolation may be included in the board or may be provided separately."
The 15th Ed. had this:
Switchboard. An assembly of switchgear with or without instruments, but the term does not apply to a group of local switches in a final circuit.
NOTE -- In the Electricity (Factories Act) Special Regulations 1908 and 1944, the term 'Switchboard' includes a distribution board.
Switchgear. An assembly of main and auxiliary switching apparatus for operation, regulation, protection or other control of electrical installations."
The 14th Ed. had this:
Distribution board. An assemblage of parts, including one or more fuses or circuit-breakers, arranged for the distribution of electrical energy to final sub-circuits or to other distribution boards."
Interestingly, the 15th Ed. describes "switchgear" as "an assembly of....switching apparatus for...protection...of electrical installations".
Then it describes "switchboard" as "an assembly of switchgear".
Then it says the term "switchboard" includes a distribution board.
So, to summarise:
In 1966, the regs defined DB.
In 1981, the regs dropped DB as a definition, but made reference to DB via a long-passed act.
In 1991, the regs reintroduced the definition of DB.
In 2008, the regs kept the definition of DB, but added the definition CU/ CCU/ ECU.
Phew, that was a lot of typing....
