Hi all,
I'm expecting delivery of a summerhouse soon. I have mains out to the area where the summerhouse is coming and planning on getting this connected to a small consumer unit for lights/sockets in the summerhouse.
The summerhouse is a 'log' type with 44mm 'logs' and is single-skinned so there's not plasterboard to run the cables behind.
I wondered what was required in order to run cables out through the 'logs' and then along the outside of the building and back in, in order to wire up wall lights and sockets?
Does anyone know if this is allowed? I realise it may not be aesthetically pleasing to everyone but thought it might be an alternative from using plastic conduit inside the summerhouse?
I thought about using armoured cable and then running it along the sides of the summerhouse outside and then drilling back through to mount sockets / wall lights as necessary?
Have you any advice on a better way to achieve this?
