Mains smoke alarms [linked]
14 Mar 2006
Essex coast
Have wiring in for three smoke/fire detectors which will be linked , need to close up the ceiling soon [plasterboard it]. Currently have twin and earth from top landing and bottom of stairs run thru to the kitchen where third fire alarm sensor will be [and pick up the lighting circuit for power] , can the wiring be connected externally to the smoke sensors or does it have to run from one to the other [radial type].
They need to be run from one point, to the next, to the next etc.
But I have some bad news for you, you use 3 Core + Earth to interconnect smoke alarms. You only use twin and earth from the supply to the first point, then 3C+E onwards along the circuit, as you need L+N+SL+E
Thanks, but that's contrary to the info I received on this forum from others and from the manufacturer.?
Another vote for 3 core+E.
What info did you receive on this forum then?
3 core+E, BTW, consists of brown, black, grey and bare earth.
I would also be interested to see any advice from a mfg that said use T+E, unless it's Nest smokes, which are radiolink as standard, and therefore just need the L+N supply.
I'm not going through 16 pages! I remember posting in the thread, wasn't that the HMO one?
The very first reply from Echo says 3C+E so.....
Seems I missed that, 38 replies, seems to have started an argument, seems electrician like to argue? ;)) Instruction manual from Kidde only shows three terminals, no earth.
If no earth, but still three terminals, then you need 3 CORES, and you still connect the bare (but sleeved) earths together.
