Angle grinder 'stuttering'
23 May 2004
I've got a 4 1/2" angle grinder that has started 'stuttering' - slowing down/speeding up randomly or simply stopping.
I've checked the brushes and they seem fine. Air blown the insides and checked the internal cable connections.
Any ideas?
Cheers
What make and how old? I suppose you could have a bad connection or a break in the mains lead
When it starts to misbehave, give the cable a tug side to side......there's a chance that the copper conductors have fractured inside the insulation, giving intermittent contact.
John :)
2 yrs old wickes 4 1/2" model.
Checked the lead visually and voltage at internal terminals.
Ok just make sure they touch the armature (not sure if that,s spelt correctly) and make sure the slots in the copper core have no crap in them, if all that,s ok must be the cable.
Hope this helps.
Andy.
Thanks Andy
They seem to touch ok, but I'll recheck
Usually the cable becomes damaged, or the switch going faulty. Could spray some contact cleaner into the switch if you have it. I took apart a faulty switch like that before and found it totally full of dust stopping it operating.
I had the same problem, changed the brushes, and then found the armature was broken. Should have just said sod it, and got a new one for the price they are nowadays.
Correct.
Cased tools tend to suffer with flex bend memory when packed away into a tight box whereby the flex gets bent severely into the same position each time. As said, it eventually breaks. And its always right by the casing exit point as this is where user stress is most prevalent also.
I know they're cheap, but one gets used to one's own tool :)
Tried another cable but still the same, so
time to replace.
Cheers for all the help
