This might be interesting: https://webstore.iec.ch/preview/info_iec60061-1{ed3.35}b.img.pdf
I don't have a copy of the full standard.
Thanks. As you say, it might well be interesting - but if we can't get access to the full standard, we may have to remain 'none the wiser'.This might be interesting: https://webstore.iec.ch/preview/info_iec60061-1{ed3.35}b.img.pdf I don't have a copy of the full standard.![]()
I realise that, and I agreed that it could well be interesting because many of the 'sheets' referred to in that list of Contents appear to relate directly to issues we have been discussing. However, in a sense that is rather 'cruel', because it tells us that the answers might be there without allowing us to see themI posted that link so you can get an idea of the content of the standard.
That sounds more like it. Thanks!However, it seems that I can access it, but only piecemeal. Watch this space while I try to find a way round that...
Thanks, and interesting. Do X, Y or Z appear in the list of defined second letters?Not sure how useful that will be though. The designation letter 'G' means only that the lamp cap has "two or more projecting contacts, such as pins or posts", but 'U' is not in the list of defined second letters. ...
It sounds a bit like that, but presumably the "lack of perfect interchangeability" does not have to be two-way. In other words, if what I read previously is correct (that "U" indicates provision for mechanical restraint), it would not necessarily follow that a G5.3 could not be used in a GUIt then goes on to state that "A lamp cap characterized in accordance with the rules in this specification may receive a designation already reserved for an existing cap. If such caps are not (or not perfectly) interchangeable with due regard to electrical or mechanical requirements, a capital X, Y, Z or U, or a combination of two or more of these, is added to the primary designation of the cap. These modifying letters follow the primary designation." ... So it seem that G5.3 and GU5.3 are not fully interchangeable.
I'm not sure that I have seen a lamp/bulb described as G5.3 (they all seem to be GU5.3).
Fair enough - all I said was that I was not sure that I had seen any - and it remains quite possible that I hadn't!There are lots - Google it.
No.Do X, Y or Z appear in the list of defined second letters?
Did you mean to type GU5.3?if what I read previously is correct (that "U" indicates provision for mechanical restraint), it would not necessarily follow that a G5.3 could not be used in a GU35 holder (merely that the retaining clip/whatever would then be redundant.
I can't find a G5.3 in the standard. There is a G5.3-4.8, which has two flat contact pins 4.8 mm wide. There is a drawing for GU5.3, but I can't see an explanation for the 'U'.do you feel that you/we are any closer to understanding what differences (if any) there are between those described and G5.3 and those described as GU5.3, and to what extent they are interchangeable?? ... or do you perhaps feel that manufacturers using one of the designations are actually 'incorrect'?
Well, yes, but it does imply you thought there was none.Fair enough - all I said was that I was not sure that I had seen any - and it remains quite possible that I hadn't!
I am still under the impression that "G" do not have a base - i.e. just glass, capless.Whatever, do you feel that you/we are any closer to understanding what differences (if any) there are between those described and G5.3 and those described as GU5.3, and to what extent they are interchangeable?? ...
Definitely.or do you perhaps feel that manufacturers using one of the designations are actually 'incorrect'?
If U, X, Y and Z do not appear in the "list of defined second letters", what letters do appear in that list??
Of course I did. Typo has been corrected.Did you mean to type GU5.3?
Exactly - but, as I said, the other way around, IF a G5.3 lamp is deemed not to require mechanical restrainf (i.e. has no 'provision for mechanical restraint'), then presumably there is no reason why it could not be used in a GU5.3 holder (assuming it 'fits', which I assume it probably does) - it would probably merely mean that the holder's 'clip'/whatever would not be required, and would not be used?Whether it would follow that a G5.3 lamp could not be used in a GU5.3 holder would, if what you read previously is correct, depend on just how that mechanical restraint was achieved.
That seems a bit different from the meaning of "G" in the Standard which stillp has told us about, doesn't it?I am still under the impression that "G" do not have a base - i.e. just glass, capless.
True, but I now believe, most fittings for a GU 5.3 lamp are designed for a GU5.3 MR 16 lamp, so a G5.3 type capsule lamp, although as you say fits, it would likely look crap.Exactly - but, as I said, the other way around, IF a G5.3 lamp is deemed not to require mechanical restrainf (i.e. has no 'provision for mechanical restraint'), then presumably there is no reason why it could not be used in a GU5.3 holder (assuming it 'fits', which I assume it probably does) - it would probably merely mean that the holder's 'clip'/whatever would not be required, and would not be used?
