Is this light suitable for outside use?
28 Jul 2012
Surrey
This: https://www.tlc-direct.co.uk/Products/SMSL3DG.html
It is IP65 rated so should be suitable for outside use, but it is under the "Indoor Lighting > LED Wall & Step Lights" section of TLC's site and the manual says: "IP65 Rated suitable for restricted external applications".
What is meant by restricted?
Regards: Elliott Veares.
Resists most water but not that from a hose directed at the light
That some outdoor environments require greater than IP65, so they can't give a blanket "suitable for outside use".
BTW - "Installation is quick and easy, with no wall channelling required!" - that'll look naff.
I have two of these installed on my front steps and 6 of the letterbox type in the back garden, well constructed and decent lumen output for the price! I was able to bring the cables in from the rear of the fittings so there are no cables on show.
Yes they are fine for outdoor use, i can get you some pics later if you want?
I like (not a lot) the way they refer to an isolation switch and then show a single pole switch.
