More complex but I'd be tempted to wire it into the lighting circuit, changing the switch to a double, and fitting a 5A lighting socket vertically below the switch.
Where did he say there wasSo when did you visit an ascertain there is a neutral at the switch?
Work of the devil.stud wall
If he's concerned about noggins being in the way, surely having to drop a cable from the switch, and possibly from the ceiling to the switch, is more likely to make that concern a reality?More complex but I'd be tempted to wire it into the lighting circuit, changing the switch to a double, and fitting a 5A lighting socket vertically below the switch.
Where did he say there was![]()
He didn't say that.It was implied when he said he could wire it from the switch.
You aren't very good at this, are you....
