The fuse is probably unnecessary at present, but If you want a switch above the counter it's one of the simpler ways.
Even simpler to use a 20 amp switch.
I dont know about "simpler", but usually/often more expensive than FCUs (with DP switches)! ... and, as has been said, don't offer the same option as do FCUs to add additional sockets in the future.Even simpler to use a 20 amp switch.
Kind Regards, John
If you'll read back in the thread, you'll find a ready made example.Why would anyone add additional sockets to a washing machine spur?
If you have any imagination or powers of thought, you ought to be able to think of at least a few possible reasons.Why would anyone add additional sockets to a washing machine spur?
Kind Regards, John
A poor one.If you'll read back in the thread, you'll find a ready made example.
That is not the sort of reply I expect from you John. More a BAS type reply.
The socket for the light could be spurred off the existing double socket next to the (unnecessary FCU).
There is no requirement for the FCU, there no requirement for isolation for the WM other than its existing plug and socket. Isolation is only required for service when the WM has to pulled out anyway.
It is desirable to be able to isolate the appliance whenever one wants to. I always isolate my washing machine when not in use, because I choose to.
There is no problem whatsoever having two fuses for the washing machine. What problems do you envisage?
And as John has hinted, having a switched FCU does allow one to spur off the washing machine socket if there was no other easy way to add an extra socket (small appliances to be plugged into).
Maybe, but it was a response to a question which itself was BAS-like - since you knew jolly well some of the reasons why people might want to add sockets, even if you personally would not regard them (in your opinion) as being 'good reasons'.That is not the sort of reply I expect from you John. More a BAS type reply
With 2 fuses you have 2 to replace when there is a fault.
Similar to my experiences. In any event, if there is no FCU, then the only fuse will probably be behind the appliance (in a plug), anyway.It's been my experience, taking the average over all my appliances, that they blow a fuse 0.0000 times per year on average. .... If one ever does, the appliance will most likely have to be pulled out from the wall to repair it or lob it in the skip. .... IME the inconvenience of having two fuses protecting one appliance is zero.
There was an easy way to spur. Off the existing double socket.
It was implied when he said he could wire it from the switch.
I take it you are not a sparks if you don't understand that!
Kind Regards, John
