1. Measure size of pipes going into wall box (after the connectors, going away from the radiator). Probably 10mm.
2. Determine make of pipe and fittings.
3. Buy two stop ends of correct size, and make if using push fit stop ends, and two pipe inserts appropriate to pipe and type of stop end. If pipe is John Guest Speedfit then:
3a. If using compression stop ends, get the ones without O rings.
3b. If using push fit stop ends, get the ones with O rings.
3c. For other makes, check Internet.
4. Drain system
5. Remove connectors near wall plate and remove wall plate.
6. Fit stop ends to disconnected pipes and tuck behind plasterwork.
7. Refill system and test for leaks (cold and hot).
8. Make good plasterwork.
3a.......Compression cap ends use Olives not O rings.
3b.......I have never seen a push fit cap end without O rings.![]()
But he said 3b...use with o rings !!I think OB was trying to say the following,
3ai....Compression cap ends do indeed use olives, but the inserts you would use with plastic pipe have o rings
3bi.....Yes, but you'd use inserts without o rings with push fit fittings.
I know what to use but you have totally confused the issue !!
If you mean to remove it permanently then I'm sure all the above advice is spot on. However if you mean to remove it temporarily then you can shut off the valves at each end and unscrew the valves from the short piece of 'pipe' which comes out from the sides of the rad. Catch the escaping water in a tray as you unscrew the valves. From looking at your pic - if you had a spanner standing vertically on the nut on the left side of the rad you need to pull the spanner towards you to slacken it, and push the same spanner away from you on the right side.I need to remove this radiator - can anyone give me advice on how I can do this?
Not all of them are anything like as good as that![]()
