I have to fit a cast metal light switch to a brick wall. There are no screws holes on the reverse so I assume its only support will be the conduit pipe that takes the wires and is screwed into the top of the switch.
This will be about a metre long and will need support from a couple of spacer bars. The wires simply run out of the ceiling so will the spacer bars be enough to support both the conduit and the light switch ?
Or is there another way of securing both the pipe and switch ?
