Another pic of the burnt wiring from other side. What should the next step be?
If going for a complete rewire, rather than trying to salvage what is there:
1: Chop all the wires, and untangle them.
2: loosen the cross head screws and pull out the 12 legs, taking care not to strain the remaining wiring inside the legs
3: loosen the grub screw in the top of each lamp holder and pull it off the metal leg.
4: post a photo of how the wiring joins the bulb holders
I think trying to salvage that would be fiddly, but if it can be done it might save a fair bit of time and wire. You could start by cutting away the obviously damaged connection and any scorched wire and see if there is any loose wire you can pull up. you should have 12 smaller wires, one thicker one, and a loop of thicker wire joining the two?
... That thing is called a wire but. ...
I too would call it a wire nut! My iPhone seems to think it’s a wire but!I think that's a typo, I would call it a wire nut. I also think they are a bit crap
Interestingly there are 8 small wires in one crimp and 4 in the other? Does it matter that they are not equal?
when it comes to joining wires, what tools/experience do you have? soldering? crimping?
But you are in charge.I too would call it a wire nut! My iPhone seems to think it’s a wire but!
