- Joined
- 11 Jan 2004
- Messages
- 46,881
- Reaction score
- 3,986
- Country
Hi folks.
I know when folk come here and say "I just cannot do this..it's not an option" often the response is "You'll have to find a way".
I could fit a deeper box, but I'd like to try and find a socket that fits first before taking drastic action.
I'm looking for a double socket that is as shallow as possible on the gubbins side, preferably rounded corners with the live terminal on the left, neutral on the right,here I am, stuck, sorry, got carried away there for a minute, and an earth terminal either side.
The other thing I want to do is fit a flush network socket that plugs into a nearby router.
I know patch leads are stranded and network cable is solid and the IDC terms are designed for solid conductors. But if I want a lead that plugs into a router at one end and connects to a network socket at the other, what does one do?
Solid is no good as it is not meant to be used in a flexible type situation but stranded will not effectively connect to the IDC terms?
Ideal solution would be a network socket that accepts a plug, but I have not seen these.
Any ideas?
Any ideas?
