- Joined
- 10 Aug 2016
- Messages
- 15
- Reaction score
- 0
- Country
Another hive thread!
Hi all wanting to replace my current digital timer/thermostat with a hive V2. I have a Worcester Bosch Green Star 30si Combi boiler.
My current setup is as shown in the attached image.
The thermostat is in my landing and boiler is in the garage.
The boiler connects to a fused switched spur and to the thermostat.
If I understand correctly I'm missing a wire from the Ns which would need to go into the Hive. If this is the case then I'm missing a wire in my current cable which I believe is 5 core (earth, black, blue, brown, grey).
Can anyone advise what steps I would need to take to get the Hive working? I'm likely gonna put the receiver next to the boiler as the wire to existing stat is separate and goes through the wall and too much faff to replace.
Thanks in advance!
PS the LS to Com wire does change from Black to brown as there are two separate wires connected at the spur via a connector.
Thanks in advance!
