Could just cry
Condensation forms when air which has invisible moisture within it caused by evaporation cools, the warmer the air the more moisture can be contained within it. Many examples..........When you open the upright freezer door a slight mist appears, this is the meeting of the warm moist air within the house being cooled by the cold air falling out of the freezer, the moisture in the warm air is condensing (turning back from a gas into a liquid). When the same air comes into contact with other cold surfaces such as your walls the same happens. Clouds form in exactly the same way, the warm moist air around us rises (for various reasons) and as it rises it cools and when it has cooled enough (reached its dew point) condensation occurs. If there was not as much moisture in the air in your house the problem would not be as bad as it is. This has been mentioned already, cooking, bathing, showering, clothes drying etc. these things cannot be avoided. Air circulation - to remind you we have 24 inch stone walls. We do all our cooking and heat our house with a Yorkshire Range (Yorkshire Range Company in you guessed it Yorkshire) we also have a large open fire in our lounge, these open fires create substantial air flow all around the house, they would not burn correctly without this air flow. This air flow in turn takes away the moist air created by living in the house. Still wish I had insulated the walls downstairs. When you go ahead with insulating you walls if you have concrete floors that have not already been insulated these should be dug up and 4 inches insulation installed.
Mike
Better than what? The difference will be marginal and won't prevent cold surface related issues which the OP has. They are better off spending their money on insulation rather than butchering the windows. As I said, for what its worth, they may as well crack open a window.
That's why there are building regulations for passive ventilation you genius. Thanks for at least partly admitting you're wrong for once - ''marginal''.
What I mean is that it's better to have trickles than not in say new windows. However passive ventilation will not make a much of a difference in this case and the money would be better spent on insulating.
Retro fitting trickles is not a easy job especially if the frames are fitted with reinforcing ally bars.
I was going to put trickle vents in, then a recent thread talked about noise from them - my bedrooms face a busyish road. So no trickle vents for us - we just put the top light windows on the latch for ventilation during the day.
I bet this house has enough sources of air flow. A chimney, gas fire, along with vents etc would do the same.
Thanks for all replies
Yes positive its not damp. We have the rendering, old chimney, guttering etc checked
If the walls are rendered that's the problem whether painted or not. Moisture is drawn in by capillary action and cannot evaporate through the impervious render. So the water content of the wall increases and its thermal propetries diminsh making the walls colder. The answer is to totally remove the render in the summer and lime roughcast the exterior if required, it could then be lime washed. This will allow the wall to breathe and dry out.
My guess is that the walls in question are ones that get wet with rain water because of prevailing winds .....correct or not ?
