- Joined
- 8 Jan 2019
- Messages
- 11
- Reaction score
- 0
- Country
I've been trawling these forums trying to find the answers to my questions and while there's plenty of advice for wiring sheds, I can't find anything that quite answers all my questions. I'd appreciate any advice.
Basically, Ive just built a wooden office shed type building in the garden, while preparing the ground I buried a length of 20mm PVC covered steel Kopex conduit running about 10m towards the house CU. I chose the Kopex over SWA cable as I need to run a thin fibre optic cable inside together with the power. (Laying SWA now would be a bit of a problem).
I plan to terminate the Kopex on two IP66 Wiska junction boxes, one on the outside of the house and one on the shed and run through 6mm 2 core+earth between them and connect through into the buildings, seperating out the fibre cable which is non conductive. The Kopex is buried 45cm deep and has a yellow "cable below" tape above it.
Inside the house, the 6mm cable will terminate on a new 32A RCBO and in the shed to a new CU with a 60ma RCD and a few MCBs.
I plan to run two circuits, for 4 and 2 sockets respectively and another circuit for a couple of lights, everything cabled to the shed CU with 2.5mm TC+E.
The shed is insulated and lined so I'm guessing there's no need for conduit behind the wall? the sockets will be on plastic bench level trunking, together with a few CAT6 outlets.
I will be getting a qualified electrician in to check it over and hopefully sign off on it, but I'd like some assurance I'm not doing anything fundamentally wrong before then.
Any advice would be much appreciated.
Cheers, Greg
Cheers, Greg
