I've taken down an existing light fitting with a view to replacing it with a nicer chandelier. The light which was removed was mounted to a 15cm long metal bar with protruding ends, and the bar itself was affixed to the ceiling using rawlplugs and a couple of screws.
What's left is what you can see below...
I've taken a poke around the inside the ceiling with a coat hanger in order to identify where the joists are but I've had little luck finding them. I've also tried the knocking/tapping method but I'm not entirely sure I've hit a joist.
Putting the problem of locating the joists aside, I think I'll have to feed the existing junction box back into the ceiling anyway - reason being the replacement chandelier has a ceiling rose with a fairly small diameter (approximately the width of the junction box)...
Does anyone have any suggestions as to how best to go about doing this?
