No problem, all new houses will be built using the same concept as the vacuum ( Thermos ) flask concept. Ultra low running costs but construction costs will make then un-buyablle for all but the rich.....
True but that's only the deciding factor if both systems are already available, or gas usage is high. A gas heating eating probably has 300+ pounds a year dead cost just by sitting there whereas an electric system is probably tens of pounds, so if your gas bill was 100 pounds a year you'd be better off using expensive electricity.No matter how much or how little heating energy a house/flat requires, unless/until the price of electricity falls dramatically and/or the price of gas rises dramatically, it will remain the case that heating energy (no matter how little or how much is needed) will cost 2-3 times more with electricity than with gas.
Dealt with by the "Heat and Meat Recovery Ventilation System"dust mites
Maybe it wasn't set up properly. The regs are pretty tight now on ventilation performance. What were the restrictions?Several years ago an aquaintance and his partner lived (?) for a few months in a "thermally efficient" home.
(?) they found the discomfort and restrictions far too oppressive to consider being in the place as living a life.
You are crystal ball gazing.No matter how much or how little heating energy a house/flat requires, unless/until the price of electricity falls dramatically and/or the price of gas rises dramatically, it will remain the case that heating energy (no matter how little or how much is needed) will cost 2-3 times more with electricity than with gas.
Zero heating houses cost no more to build.No problem, all new houses will be built using the same concept as the vacuum ( Thermos ) flask concept. Ultra low running costs but construction costs will make then un-buyablle for all but the rich.....
There will be free air flow using air to air heat exchangers.And owners have to live with a gazillion dust mites because there is no free airflow to push them out of the house?
A poorly designed or built one.Several years ago an aquaintance and his partner lived (?) for a few months in a "thermally efficient" home.
Hadn't heard about this syndrome, but I'm sure it is a concern for all buildings regardless of efficiency, they should be well designed and not cause an unhealthy environment but that doesn't always happen in reality!
